Message 1 of 2
VDSL supports RJ45
Just had BT engineer change our NTE5a to a modern OpenReach VDSL faceplate.
I heard the RJ11 socket can also fit a RJ45 cable too.
Does the BT router support RJ45 broadband input using one of the 4 gig ethernet RJ45 ports?
If not, I also own a LINKSYS WRT cable/fibre router. Possible to use this as a placement?
1 REPLY 1
Message 2 of 2
Re: VDSL supports RJ45
@kcdenton
The BT Home hub has its VDSL input on a RJ11 socket. not one of its Ethernet ports.
You cannot use a cable router, it has to be a VDSL modem/router, so just use the BT Home hub instead.
