Message 11 of 41
Re: Broadband Performance / No recourse of action
@cjbev wrote:
So does seem like something changed in the infrastructure to drop from 5 to 1 in the last few weeks?
Probably a new customer connected or a customer with a faulty pair swapped to a pair that disturbs your pair that was previously spare.
Message 12 of 41
Smart Hub 2
Message 13 of 41
Upstream sync is 800kbs
Message 14 of 41
Ouch!
Message 15 of 41
Aye!
Message 16 of 41
Something is wrong there.
Have you tried a short (20 second) disconnection of the incoming DSL line, and then see if it reconnects at a higher speed.
A loss of higher frequencies can be caused by changes in your own internal wiring, so yo really need to check the connection speed at the test socket.
Message 17 of 41
Hi,
I had an engineer out beginning of July who used his own kit (hub/laptop/cables) to test the line out and I believe he used the test socket as well and got the same results. His recommendation was (because I had a netgear hub) to get a BT hub just to eliminate that (even though he had tested it with a BT hub) - after contacting BT today and going through all the same tests the response was that they didnt guarantee upload speed....needless to say I'm not happy about that response....
Message 18 of 41
If you cannot get a better upload connection speed, even at the test socket, then you must have a lot of high frequency interference or loss, which is making the top part of your frequency allocation unusable.
It could be caused by a split pair on another circuit which would cause a lot of crosstalk. Its going to be almost impossible to locate, although a pair change may help, if that has not already been tried.
I get a better upload  connection speed on my ADSL line.
Message 19 of 41
Thanks - How would I get BT (or Openreach) to test/check this?
Message 20 of 41
Just a quick check, are you using any powerline  adaptors, as they can cause this type of interference?
