Message 31 of 41
Re: Broadband Performance / No recourse of action
The engineer that came out did a quiet line test and all was ok.
Message 32 of 41
The issue of course is that BT dont guarantee upload speed - that was there answer and effectively ended the call.....
Message 33 of 41
Have you checked the line yourself with a phone, as the problem may be intermittent noise?
Message 34 of 41
Can I do that without connecting to the test socket?
Message 35 of 41
Yes, but if there is noise you would need to repeat it at the test socket to eliminate your internal wiring as the cause.
Message 36 of 41
Just tested - no noise (Its a hands free phone) no crackle or anything like that
Message 37 of 41
I think this is going to have to be looked at by one of the moderators, would you agree @licquorice
Message 38 of 41
Yes, probably the only way to get an engineer visit.
Message 39 of 41
Thats much appreciated!
Message 40 of 41
I have asked a moderator to provide assistance, they will post an invite on this thread.
They are the only BT employees on this forum, and are based in the UK.
