Message 1 of 19
Broadband
I am hoping someone can help. Sorry for the long push but with working from home I need a stable connection. Up until last week I was getting the speeds I pay for and bt can see this on there side. From Monday last week the speed dropped and was losing connection. They said last week I had a bad week with it dipping. They sent an engineer out who said everything was fine. Still not getting the speeds I pay for. So I contacted bt again who are again sending out another engineer on Wednesday not sure what this one can do that the other one did. They also sent me out a new smart hub which I put in on Saturday. I am at a lost end as nothing has changed my side nothing moved or installed.
Keels
18 REPLIES 18
Message 2 of 19
Re: Broadband
welcome to the BT community forum where customers help customers and only BT employees are the forum mods
in order for the forum members to help please can you post the stats from your router (if hub enter 192.168.1.254 in your browser) and if  HH5 then go to troubleshooting then helpdesk and if HH6/SH2 then advanced settings then technical log information .
Have you tried the quiet line test? - dial 17070 option 2 - should hear nothing - best done with a corded phone. if cordless phone you may hear a 'dull hum' which is normal
enter your phone number and post results  remember to delete number   https://www.broadbandchecker.btwholesale.com/#/ADSL
Have you turned off smart setup in hub manager
Someone may then be able to offer help/assistance/suggestions to your problem
Message 3 of 19
Re: Broadband
Product name:
BT Hub 6A
Serial number:
+084316+NQ65042542
Firmware version:
SG4B1000E020
Firmware updated:
10-Aug-2019
Board version:
1.0
Gui version:
1.115.0
DSL uptime:
0 Days, 1 Hours 57 Minutes 3 Seconds
Data rate:
11.90 Mbps / 33.08 Mbps
Maximum data rate:
11954 / 43964
Noise margin:
6.9 dB / 11.6 dB
Line attenuation:
30.2 dB
Signal attenuation:
26.5 dB / 30.2 dB
VPI / VCI:
0/38
Modulation:
G_993_2_ANNEX_B
Latency type:
Fast Path
Data sent / received:
204 MB Uploaded / 1 GB Downloaded
Broadband username:
BT Wi-fi:
Active
2.4 GHz wireless network name:
BTHub6-5HTS
2.4 GHz wireless channel:
Smart (Channel 11)
5 GHz wireless network name:
BTHub6-5HTS
5 GHz wireless channel:
Smart (Channel 44)
Wireless security:
WPA2 (Recommended)
Wireless mode:
Mode 1
Firewall:
On
MAC address:
24:20:C7:7F:97:41
Software variant:
Boot loader:
7.33.1
yes the quiet test was fine
yes smart setup is turned off this was done by bt
BT said on phone earlier today i was getting speeds of 60mbs up until last week then it dropped
Keels
Message 4 of 19
Re: Broadband
The first engineer clearly wasn't diligent enough and didn't find the fault, your line stats are terrible. Hopefully the next engineer will have more success.
Message 5 of 19
Re: Broadband
so you think there is a problem with my phone line and this would be affect my broadband
Keels
Message 6 of 19
Re: Broadband
Message 7 of 19
Re: Broadband
Well hopefully the engineer on Wednesday can resolve it, as not had a problem since last Monday and then it started dropping. Working from home I need a stable connection.
Keels
Message 8 of 19
Re: Broadband
Hi i think my line stats have got worse can someone take a look at these for me.
Product name:
BT Hub 6A
Serial number:
+084316+NQ65042542
Firmware version:
SG4B1000E020
Firmware updated:
10-Aug-2019
Board version:
1.0
Gui version:
1.115.0
DSL uptime:
0 Days, 5 Hours 52 Minutes 51 Seconds
Data rate:
10.99 Mbps / 49.11 Mbps
Maximum data rate:
10998 / 52100
Noise margin:
6.2 dB / 6.9 dB
Line attenuation:
40.6 dB
Signal attenuation:
26.5 dB / 40.6 dB
VPI / VCI:
0/38
Modulation:
G_993_2_ANNEX_B
Latency type:
Fast Path
785 MB Uploaded / 380 MB Downloaded
Broadband username:
BT Wi-fi:
Active
BTHub6-5HTS
Smart (Channel 11)
BTHub6-5HTS
Smart (Channel 44)
Wireless security:
WPA2 (Recommended)
Wireless mode:
Mode 1
Firewall:
On
MAC address:
24:20:C7:7F:97:41
Software variant:
Boot loader:
7.33.1
Keels
Message 9 of 19
Re: Broadband
No idea why you would think that, they are much improved.
Message 10 of 19
Re: Broadband
sorry not sure what I am looking at, as I was looking at the Line attenuation as this is higher than it was on last one i done.  Also my dsl uptime seems to be dropping over the last couple of days it start at 5 hours is this normal as i thought it should show longer than this,  Is it worth still having the 2nd engineer check everything over.
Keels
