Message 21 of 23
Re: Bt Engineers can't fix my broadband
I've had to reset it many times for this exact reason.
I change the password for the wifi, save, thats OK. I then change the Channel just for the 5Ghz band and save, it saves, then I reconnect to the wifi and enter the password I changed it to, it wont accept it. I try the original password , doesn't accept it.
So I have to reset the SH2 and start over. Simply won't work. I've no idea what password its expecting. This is just one of the reasons I want to use a 3rd party router, so I can split the bands with different SSID's.
EDIT : I've not tried to set BOTH bands at the same time, so I can try that.
Message 22 of 23
Hi @LeVzi,
It may be worth us looking into replacing your Smart Hub 2 if there appears to be an issue with it.
Let me know if this is something that you'd like us to do.
DanielS
Message 23 of 23
I appreciate that, i'll wait to see what happens on Wednesday when Openreach come out, and if im stuck with the SH2 , i'll get it returned, because I literally cannot change the channel.
