Message 1 of 9
Bt synergy cordless phone
Why is a C showing on the phone screen and there is terrible interference on the line
8 REPLIES 8
Message 2 of 9
Re: Bt synergy cordless phone
@JenniferMelvin45
Who provides your phone service?
Message 3 of 9
Bt is the provider,  problem happened after a power cut which last only a second
Message 4 of 9
Remove the power to the base unit for about a minute, and that should clear the problem which can be caused by a short power loss.
Message 5 of 9
Sorry but no luck the phone  is still displaying C  have checked batteries they are ok
Message 6 of 9
Has the noise gone away? You may also have to check the date and time is correct.
Message 7 of 9
Hi @JenniferMelvin45   Looking at the user guide it is not C-0 flashing? This means that the date and time needs to be set on the answering machine.
Message 8 of 9
Wow not sure how but it appears to be ok, suddenly it made a strange noise from the base unit and cleared itself, thank you for your help very grateful
Message 9 of 9
A short mains interruption can disrupt the internal software communications. I am pleased its now working.
