Message 11 of 12
Re: Can I use left behind BT Hub?
No, you've misunderstood. The credentials are generic which means they are exactly  the same in every BT hub.
Any BT hub will work on anyone's  BT connection without having to change anything. They are "plug and play".
Message 12 of 12
Oh, of course. My mistake.
Fingers crossed for when BT come to set us up.
Thanks for your help.
