Message 191 of 406
Re: Can't update from McAfee to Norton
I get the following message when click on the manage virus protect
The resource you are looking for has been removed, had its name changed, or is temporarily unavailable.
been like it all day
Message 192 of 406
The only way I could install Norton Security on my iMac was to delete these McAfee files that remained in my computer even after uninstalling McAfee. Took me two days. Helped by BT Community and a free programme App Cleaner and Unistaller. https://twitter.com/messages/media/1485157930097950725
Message 193 of 406
This has happened to me too.
but Now I installed Norton after I read a post in BT Community that you need to delete all remaining McAfee files. I have done that by locating these files in Finder on my iMac. Then the installed programme Norton Security allows you to log in by your BT ID and Password.
Message 194 of 406
@internetq and @neil4768  welcome to the community and thanks for posting. I'm sorry about the problems you're both experiencing updating BT Virus protect to Norton.
This error message indicates that your BT ID is a string of text and not in the format of an email address. Updating it in MyBT to an email address will fix this.
If you log in to MyBT on a web browser then at the top of the page click 'Your details' then click 'Profile' you can edit your username on that webpage.
Neil
Message 195 of 406
BT should have linked us to the McAfee Consumer Product Removal Tool as shown here
Very quick and easy to use, and ensures other products can be installed without difficulty or conflicts.
Message 196 of 406
@Neil0 thank you for your reply, however, when I want to add my email when updating my profile. I get the following message:-
This Recovery email should not match with BT username.
As my BTID is the name I am using on my email how do I get around this?
Regards
Neil
Message 197 of 406
I didn't have McAfee on my laptop. was already using Norton.
Tried the BT update and had to uninstall Norton but then took me hours to sort getting it back again!!
My BT account is still telling me I need to update to Norton when I'm already using it.Publication1.jpg
Message 198 of 406
@neil4768 That means your email address is already a BT ID. You might be able to change the account holder status on the BT ID that uses your email which will allow you to manage all your BT services from that ID instead.
  1. Log in to My BT >
  2. Click on Settings and Your account.
  3. Scroll down and you'll see if you're an Account holder or Account manager.
  4. Click on the I should be the Account holder link and follow the steps.
Neil
Message 199 of 406
@NeilO i am the account holder, not sure what to do now.
Regards
Neil
Message 200 of 406
@neil4768 do you have more than one account associated with your BT ID? If so you need to make sure you're the account holder for both.
Neil
