Message 11 of 17
Re: Cannot play recordings ipc6041
Hi, @daverail I'm sorry that didn't help. I've seen this issue before and it was resolved by doing a factory reset on the box. Make sure to try the option that keeps your recordings first. Post back and let me know how you get on.
Neil
Message 12 of 17
Hi NeilO,
i have done the reset to keep the recordings and now when i select the programmes from the recordings screen i get “the recording of landscapers is unavailable”.
thanks,
Message 13 of 17
Hi @daverail Thanks for trying that, can you try recording and playing something new to see if that works?
Neil
Message 14 of 17
Hi Neil,
just tried:   changed channel to 342. Pressed red R on remote and program records. Pressed the house and go to recordings and watch list. Found the currently recorded programme and it plays fine. It kept asking for parental control which i entered. Could this be part of the problem?
thanks,
Dave,
Message 15 of 17
@daverail Thanks for doing that for me, that sounds like you've sorted the ipc6041 issue by doing the reset, unfortunately, it won't fix the programs that won't play but you still might get these by going into the Now app.
The parental control pin is required to watch certain programs pre-watershed and it shouldn't cause any issues.
Neil
Message 16 of 17
Hi Neil,
Thanks for your help. I have found them on NOW, so at least i can watch them.
Thanks,
Dave,
Message 17 of 17
@daverail That's great, I was glad I could help.
Neil
