Message 1 of 12
Completely shut out of My BT app
I cannot get into the BT app using the 'Forgot password' function. It just says 'an error occurred' 'try again'. I've spent a couple of days trying again. What can I do? Is there a way to reset the Smart Hub 2 to clear all app controls?
11 REPLIES 11
Message 2 of 12
Re: Completely shut out of My BT app
Hi @alison4 and welcome to our community.
I'm sorry you're having problems with the App. Are you able to delete and reinstall it? Can you post a screen grab of what you're seeing?
Cheers
David
Message 3 of 12
If it helps I haven't been able to access the app since the latest update. Clearing cache, data and reinstalling hasn't helped. Can't get past a message saying 'Something went wrong'.
Message 4 of 12
Thanks for posting @sno1989 . I'd like to take a closer look at this for you so I'll drop you a private message now so you can get in touch.
@alison4  Is this the same issue you're seeing?
Cheers
David
Message 5 of 12
The message posted by the other user is the same message that I  seeing. Thank you.
Message 6 of 12
@alison4 have you tried @DavidM's suggestion of deleting and reinstalling the app to see if that helps?
Neil
Message 7 of 12
I have tried deleting and reinstalling three times in the last couple of days. I continued to get the 'Oops' message and the password I thought I'd set up wasn't recognised.
Message 8 of 12
Same here.
Looking at all the 1 star reviews on Google Play store from the last few days, I don't think it's an isolated issue.
Message 9 of 12
Hi @alison4 and @sno1989 do the same log in details work on the MyBT website?
Message 10 of 12
I don't get that far Neil, it errors before that unfortunately.
My login details do work on the website though 👍
