Message 11 of 18
Re: Connecting a new router
Please find below: 4.png
Message 12 of 18
There's your problem, you have a G.Fast service which the Asus doesn't support.  You need the Asus DSL 88U to support G.Fast
Message 13 of 18
Ah, aha, fair enough.  I got that asus router as it was the only DSL router that was AX. Ill likely return  the one I got and purchase the one you suggested in that case.
Thank you ever so much for your help, and for taking the time to reply to me.
Message 14 of 18
G.Fast is a very niche market and there are extremely few routers with the capability, in fact the 88U is probably about the only one!
One of the Zyxel models does as well I think.
Message 15 of 18
@Joao-Patricio
I'm a firm believer in Asus modem/routers but the DSL-AC88U probably isn't one I'd recommend. I don't think it's been very successful and lacks firmware support , the last being over 2 1/2 years ago.
As @licquorice says Zyxel do one - the Zyxel XMG3927-B50A - which might be worth a look.
Message 16 of 18
@licquorice
Thank you so much for your suggestion, and thank you @TimCurtis for the heads up on that. I've been looking into that Zyxel router. I presume that there aren't any Wifi 6 capable routers that would work with G.Fast.
One thing I was wondering, do you know if it would be possible to set up a VPN with that Zyxel router? I want to be able to be at my workplace and be able to VPN into my home network and wake-on-lan my home computer.
If you don't know, then that's fair enough, thought I'd ask.
Message 17 of 18
@Joao-Patricio
The specs say Wake-up-on-Lan is supported & there are Zyxel apps available so I guess that'll work but nothing about VPN. That surprises me TBH but contact Zyxel support for confirmation one way or the other.
Message 18 of 18
Would you actually need a VPN, just port-forward port 9 to the broadcast address 192.168.1.255 and any devices listening on the LAN should wake.
