Message 21 of 34
Re: Connecting cctv
Its possible the hub is faulty. Try calling customer services 0800 800150 and ask for a replacement hub.
Message 22 of 34
Re: Connecting cctv
I contacted amazon tech support they think the camera maybe faulty.
Message 23 of 34
Re: Connecting cctv
There is something definitely wrong with the hub if you can't access Smart setup to turn it off. If the camera was working previously and the only change you have made is changing router, it would seem more likely that that is where the fault lies.
Message 24 of 34
Re: Connecting cctv
Yes I can give them a call thanks
Message 25 of 34
Re: Connecting cctv
I eventually  found smart setup when I went on my laptop and switched it off.It does not come up on my phone. It didn't  cure my problem. I contacted bt after a bit of feeling around they said bt hub 2 cannot split 2.4ghz and 5ghz automatically.Also cannot be done manually  successfully. So free of charge they are sending another hub with the same package  as hub 2 that should work with ip cctv.
Message 26 of 34
Re: Connecting cctv
Hi @Steviejay1959 and thanks for posting.
I'd be very interested to know if the new hub sorts this so please post back and let us know how you get on.
Cheers
David
Message 27 of 34
Re: Connecting cctv
Some devices do seem to have a problem with both bands having the same SSID, but I don't recall any cameras having a problem. You can always try turning off the 5Ghz wifi and see if the camera connects ok.
Message 28 of 34
Re: Connecting cctv
Message 29 of 34
Re: Connecting cctv
That was the first resetting  I did last week wasn't  a success due to the fact it is not a success  doing it manually.I also tried today  since they did a bit tweaking with the hub yesterday.The whole problem bt hub 2 can't  handle camera's  that need Internet connect before wfi.
Message 30 of 34
Re: Connecting cctv
???? How can you connect to the internet before connecting to wifi?
