Message 1 of 5
Digital Phone
Had a BT email saying will be transferred to digital phone soon. Which says I can plug my existing phone into the Green socket on my Smart Hub 2. I have recently had FTTP installed with a new Smart Hub 2 which is connected to the ONT. Can I fit my existing phones to this Smart Hub2 as instructions show a FTTC Smart Hub 2 connected to the standard copper phone socket. Any advice will be appreciated
4 REPLIES 4
Message 2 of 5
Re: Digital Phone
yes if it's a smart hub 2 there'll be a phone port (green) under a black sticker with white writing stating "Digital Voice" .
Message 3 of 5
Re: Digital Phone
Yes, that is correct have found the Grenn phone socket, can a exiting standard phone work connected to that socket with the Smart Hub 2 connected to a FTTP ONT modem
Message 4 of 5
Re: Digital Phone
Yeah, essentially the Smart Hub 2 is acting as a bridge that enables your phone to work over Voice over Internet Protocol (VoIP). It works the same way no matter if your broadband is via FTTC or FTTP.
Message 5 of 5
Re: Digital Phone
Thanks for the info, much apprieciated
