Message 11 of 13
Re: Digital Voice problem when ringing a number that starts with pre-recorded audio message
Hi @SteveR1260  thanks for posting back and this is a strange one and I can understand how important the service working correctly is for you. I've sent you a Private Message so you can get in touch with the Mod team and we'll be happy to get this looked into further and fixed for you.
cheers
John
Message 12 of 13
@SteveR1260 I've never experienced the problem that you're describing, and as you've already had the handsets replaced, the only other variable that I can think of in Settings is Single/Multi Call. I have mine set to Single and I think it was set to Multi by default.
I have no idea why it would make a difference but it might be worth changing to Single and see if that makes a difference. On the handset, select Menu/Settings/Line Settings/Call Settings and change Call mode to Single call and Save.
Message 13 of 13
Hi Andy
Just tried it and it does not make any difference.
