Anonymous
Not applicable
Message 11 of 21
Re: Digital Voice with new fibre installation
It wasn't help
Anonymous
Not applicable
Message 12 of 21
I'm not sure why people purport to offer help when they don't actually know the answer
Message 13 of 21
@Anonymous wrote:
re-read my original post. it IS available according to BT
No, its available according to some random Openreach engineer.
Message 14 of 21
@Rob364 's response explained the reason.
Message 15 of 21
If you know VOiP is available to you why are you asking if it is then?
Message 16 of 21
I never said it wasn’t available. I said it might not be.
Anonymous
Not applicable
Message 17 of 21
You clearly didn't read fully what I posted. It wasn't just some random OpenReach engineer - which is offensive - it was also BT.
So, if you can't actually comment constructively why bother? Cleary a bored troll looking to up their ratings by posting rubbish.
Aspiring Expert - LOL
I didn't ask if it was available - try reading what I said.
Message 18 of 21
You come onto the forum, ask a question that sounds like you already know the answer and then slag off everyone who trys to help you.
Troll, well if the cap fits!!
(If I have helped you in any way please click the thumbs up. Thank You)
If I have solved your Issue please click the "Mark as accepted solution" button.
Message 19 of 21
Quotes
"I don't know why BT didn't order Digital Voice at the time"
You had to speak to them beforehand as I said in my earlier post as there are limitations on what devices can be used.
The newer ONT's do not have a battery backup and they need to know if you have any means of communication, good Mobile network, that can be used in a power cut. Those who need good access to medical facilities and emergency services for whatever reason may have to be provided with an emergency back up power supply .
Message 20 of 21
Couldn’t care less about those ratings they dish out.
I’ve never been one to seek recognition or want praise.
Not one for asking questions I know the answer to already either.
