Message 1 of 5
Disconnect-reconnect problem
Connection is constantly disconnecting and then reconnecting. Tried the online diagnostics and they come back clean. I am using an Ethernet connection and have tried two newly bought cables.
4 REPLIES 4
Message 2 of 5
Re: Disconnect-reconnect problem
@steely09
Is there any noise on your phone calls? Dial 17070 and select option 2, there should be no noise between the announcements.
Which BT Home hub are you using?
Message 3 of 5
I don't think it's a line issue. The router doesn't disconnect from the internet. The computer is disconnected from the router.
Message 4 of 5
BT smarthub type 2
Message 5 of 5
Hi @steely09  and welcome to the community.
Sorry for the late reply. Did you manage to get this sorted? Is there any pattern to the drops etc? If you're still having problems give us as much detail as possible and we'll try to help.
Cheers
David
