Message 41 of 65
Re: Discord images being blocked
We are not trying to share images, we are trying to view images on Discord. Now it seems we are being blocked from even updating Discord. This is becoming very frustrating, has anyone from BT look at any updates to Web Protect as a previous poster mentioned. I also just want to add it not only Discord that this is affecting.
Message 42 of 65
Hi everyone,
Thanks to those who have sent over details, I'm really sorry about the problems being experienced and I would like to apologise for any inconvenience caused. We've raised this with the network team who are currently investigating.
Can anyone affected by this please post back to let us know if you have parental controls active on your broadband and if so what filter level are they set at?
Neil
Message 43 of 65
Hi Neil,
I don't have any parental controls active on my broadband.
Message 44 of 65
Hay I also don’t have any active
Message 45 of 65
Hi Neil
I don’t have any parental controls set. Web protect is on.
Message 46 of 65
No parental controls
Message 47 of 65
No parental controls enabled.
Thanks for the update as well, information getting back to us users on the forums is appreciated. Hopefully things will be resolved quickly.
Message 48 of 65
I would like to add a little information about the Discord issue:
If I try to view the image that has been posted on Discord, it is blocked. But if I right click on the image, copy the link, open any bowser (chrome/edge) and then paste the link into browser, I am able to view the image.
I have tried this on my tablet with success every time. It's not a permanent solution I know, but it helps if you need to view the image.
Message 49 of 65
@SL23 wrote:
Hi Neil
Hi @SL23,
If you turn Web protect off are you able to view the images?
Matt
Message 50 of 65
Turning off web protect worked for me
