Message 11 of 21
Re: Extremely slow internet speeds.
Using Wireless
Message 12 of 21
It's both wireless and wired connections. Hub light stays blue but it sometimes takes 30 secs for a wabpage to load.
Message 13 of 21
run btspeedtester and post results  must be done with ethernet connection not wireless
https://www.speedtest.btwholesale.com/
Message 14 of 21
So it took 5 mins for the page to load then the ping shot up to 3500 then everything goes to 0.
Message 15 of 21
Here is one where its worked for a minute or two, gone off again since.
Message 16 of 21
Message 17 of 21
It seems to work for a few seconds then go off for 5 minutes, All with the light staying blue.
Message 18 of 21
what type of master socket do you have
have you tried connecting hub to test socket with a filter to eliminate problems with the master socket?
if you have type 7 have you made sure it is firmly clipped in place as that has been a problem with others
Message 19 of 21
I have number 7. I have reconnected all cables, no change.
Message 20 of 21
so have you now connected to the test socket with a filter to see if that helps by eliminating the master faceplate?
