Message 21 of 31
Re: FTTP Install underground v overhead
Refer to EPT/ANS/A011
PARAGRAPH  4.13
Message 22 of 31
I'd rather take note of the install engineer who does the job day in day out than something you can't even be bothered to link to.
Message 23 of 31
It's an internal openreach document so therefore can't be accessed by everyone. I assumed from some of the answers on here that a few of the contributors may be OR engineers.
Message 24 of 31
Yes there is an OR engineer in this thread I'm sure he knows the required max length for FTTP drop wire is. If you supplied the document link if it is an internal OR doc then those who have OR site login details may be able to access it.
Message 25 of 31
Message 26 of 31
1.1                        Span Length Limits
For all new / replaced Dropwires, the maximum dropwire span lengths must not be exceeded when the job is completed.
These are as follows:
  • 68 metres when using an *Eyebolt 1A, Eyebolt 2A or Bracket 22/44/51.
  • 40 metres when using a Bracket 32.
  • *40 metres when an Eyebolt 1A is fitted to a rendered / harled wall and the Dropwire does not cross any Road / Carriageway.  (See Section 4.9.1 for full details.)
  • Cable Drop Wiring No.15 can be used for spans up to 68 Metres including road crossings.
1.1.1                    Exceptions to the 68m span limit
The only exception to the 68m limit is for Fibre feed cables to a CBT.
In situations where cable installation in existing U/G duct is not economically viable, the alternative is to span a new overhead fibre cable between existing DP Poles, therefore bypassing the damaged U/G section.
However, sometimes the spacing between existing poles may be found longer than 68 metres. Where the above scenarios are encountered and where use of an overhead alternative is required, but not possible as the distance between poles are greater than 68m, the following exceptional span length options may be utilised.
This policy applies to Fibre cables feeding CBTs only.
It excludes the following,
  • Fibre cables beyond the CBT i.e L2C house-end feeds
  • Creation of new copper span situations greater than 68metres
Message 27 of 31
Sorry for the repeated paragraphs.
Message 28 of 31
As I said, this thread refers to FTTP and it will be to a CBT.
Message 29 of 31
Fibre feed to a CBT is not a dropwire to a customers house. It's a feed from the splitter/Intermediate Joint to the CBT. This thread is about dropwires FROM CBT to customer.
Message 30 of 31
I'm sure @Starwire  will give a definative answer.
