Message 11 of 22
Re: FTTP installation
Just post photos, reduce the size with Paint or some such.
Message 12 of 22
@ScottMckay19 wrote:
Yes - but just with a single opening
Then that would just be an extension socket, from the main master socket downstairs. If the RJ11 DSL lead from the home hub plugs directly it it, without a filter, then its probably an RJ11 socket, and its simply a data extension socket from the master socket.
Message 13 of 22
Which socket are you connecting to on the hub, the DSL socket or the WAN socket?
Message 14 of 22
The wan socket
Message 15 of 22
I'm guessing you have a copper phone line downstairs and fibre upstairs but that doesn't stack up with the installation information you were given.
Does the white box have LEDs labelled PONand LOS?
Pictures really would make this easier
Message 16 of 22
Nope. I believe downstairs is in fact copper as this is where the old style broadband came in, then when we changed to BT infinity “fibre” it all went upstairs
Message 17 of 22
Sounds like a data extention socket.
Just have a word with the install engineer when he comes.
Message 18 of 22
Can't be, that would connect to DSL socket not WAN. I suspect 'white box' is Openreach modem. We could have resolved this hours ago with pictures
Message 19 of 22
I know the difference between a socket and a modem mate, I’m at work so can’t get photos or I would.
Message 20 of 22
The only way you can connect a socket to a hub WAN port is if the socket is an RJ45 supplying Ethernet from either an ONT or modem elsewhere.
