Message 31 of 34
Re: Fibre 2 Speeds Still Capped at Fibre 1
Thanks in advance for any advice 🙂
Message 32 of 34
Have you checked the landline for dial tone and ok then check for line noise
Message 33 of 34
Have just done the quiet line test using a spare corded phone.  Everything is silent.  No crackles or popping noises.
Message 34 of 34
BT checked my line after BT speed test showed ‘Slow Connection’.  They’ve said that there is a fault on the network and an engineer has been booked for tomorrow to try to rectify the problem.
