Message 21 of 34
Re: Fibre 2 Speeds Still Capped at Fibre 1
Reported to the BT Diagnostics Bot as a phone line fault.  Someone rang back after a few text messages  and told me there is no fault on the phone line and my StayFast guarantee for broadband is 41mb, and I’m within it so nothing can be done.
My Fibre 2 router stats have been identical for three days now, despite the odd dropout. Still showing just under 55/12. Fibre 1 also showed the same stats, but I’ve been told that I won’t get any better because my line isn’t capable of higher speeds. The fibre cabinet is very close to my address and I had much faster speeds not that long ago…
Message 22 of 34
I'll ask if one of the mods can take a look.
Message 23 of 34
Thank you 🙂
Message 24 of 34
Hi @NorthernStar and thanks for posting.
I'll be happy to take a closer look at this for you. I'll drop you a private message now so you can get in touch. Thanks @licquorice for bringing this to my attention.
Cheers
David
Message 25 of 34
Thank you, David.  I’ve just replied to your pm.
Message 26 of 34
Thanks @NorthernStar ,
We'll get back to you soon.
Cheers
David
Message 27 of 34
Many thanks to David, Daniel and others in this thread.
It was discovered that my line had been banded. The banding has been removed and my speeds have been increasing. I’m now on 18488/62973 after being up for just over five days.
Message 28 of 34
Hi @NorthernStar  thanks for the update and it's good news that the banding has now lifted 🙂
Cheers
John
Message 29 of 34
Sadly the problems are back but are much worse.   Throughput, attenuation, speeds well below ‘Stay Fast’ etc.  It’s worsened since yesterday.  Looks like a fault somewhere on my line or at the fibre cabinet, which I can almost see from my house.  Shocking attenuation figures for the first time ever.  They have always been around 9 to 11 before.
Message 30 of 34
