Message 1 of 18
Fibre 2 upgrade
I singed up to BT broadband Fibre 2 a couple of months ago. I notice now they have faster services. Can I upgrade??? e.g. Will the upgrade take over my current contract?
thanks
17 REPLIES 17
Message 2 of 18
Re: Fibre 2 upgrade
You can upgrade at any time, your existing contract would then be replaced with the new contract, there is no penalty for upgrading and ending the original early.
Message 3 of 18
Re: Fibre 2 upgrade
enter your phone number and post results will show what is available to you   https://www.broadbandchecker.btwholesale.com/#/ADSL
Message 4 of 18
Re: Fibre 2 upgrade
Well that's good news - thanks!!!
They should mention this on the upgrade site so people know for sure.
Message 5 of 18
Re: Fibre 2 upgrade
One other thing if I may - if there any speed restriction on Full Fibre? e.g. is it unlimited or does it slow down once you have use so much data like Vermin Media does?
thanks
Message 6 of 18
Re: Fibre 2 upgrade
unlimited
Message 7 of 18
Re: Fibre 2 upgrade
Unlimited as is VM.
Message 8 of 18
Re: Fibre 2 upgrade
Mmmmm unlimited is a bad choice of word. I mean't "unrestrcited".
VM restricts your bandwidth after a decidly small amount of data used.
Message 9 of 18
Re: Fibre 2 upgrade
I have the full fibre to the house and been through the checker fine. BT webpage fails though and asks me to ring them... but can't get through.
Sale lost I guess.
Message 10 of 18
Re: Fibre 2 upgrade
BT have no limits, no restrictions etc, you can use as much as you want, when you want, you won't be told you're using too much or slowed down.
