Message 11 of 18
Re: Fibre 2 upgrade
I feel you already have FTTP as you posted then phone FTTP team 08005874787 and see about upgrade
Message 12 of 18
Re: Fibre 2 upgrade
@TessTickleswrote:
I have the full fibre to the house and been through the checker fine. BT webpage fails though and asks me to ring them... but can't get through.
Perhaps your telephone is with Virgin? Further, perhaps you have Virgin cable and, if so, I doubt BT can utilise this.  Mind you, I am not an expert regarding cable and FTTP.
Message 13 of 18
Re: Fibre 2 upgrade
@Carlusha
BT and virgin connection are not interchangeable
if you have virgin you need a new installion for BT
Message 14 of 18
Re: Fibre 2 upgrade
VM do not have a Fibre 2 tier so doubt the OP has VM.
Message 15 of 18
Re: Fibre 2 upgrade
Tried as stated, waited 30 mins, tried again... another 30 mins. can't get through to anyone
Message 16 of 18
Re: Fibre 2 upgrade
I am already on BT Fibre 2 (fibre direct to house) I do not have any VM services.
I don't use the BT landline though - who does these days????
Message 17 of 18
Re: Fibre 2 upgrade
Yes, I am aware of that. I was confused by the OP @TessTickles referring to Virgin and his inability to complete the checker.
Message 18 of 18
Re: Fibre 2 upgrade
Not  - my ability to complete the checker 🤔 The ability of the checker to perform it's task. I completed my part perfectly. 👌
