Message 11 of 13
Re: Halo300+ Full Fibre FTTP - Upload capping at 15-20mbs on SmartHub2
Hi @pauldavies1980,
I've tested the connection and the upload speed is showing as 110 Mbps.
I'm sorry this took so long to fix. Have you noticed an improvement at your end?
Thanks,
Paddy
Message 12 of 13
Hi @PaddyB,
Absolutely no problem at all and thank you so much for sticking with it, I have indeed noticed the restrictions have been lifted and had noted earlier this evening the upload had shot up to 110. For some reason however, whatever changed on the SH2 knocked off the 4G backup router, it was showing up on the SH2 as an LTEModem-1720 with an IP address but the red light was flashing (hard wired) eventually after 3 or so factory restarts (power cycles did nothing) on the 4G unit it started to talk again which SH2 then recognised. (I guess flushing out the last of the gremlins)
I cannot thank you enough, for your help, support & communication throughout which has been brilliant, and in my opinion over and beyond. 😁
Thank you so much!
Regards,
Paul
Message 13 of 13
Hi @pauldavies1980,
That's no problem at all, I'm glad I was able to help.
If you ever need any help with your BT services, you're always welcome on the Community.
Paddy
