Message 1 of 10
Help configuring TP Link TD-W8961N
Hi all,
I have been banging my head trying to configure the TP Link TD-W8961N with no luck....
These are the settings I put in the wizard. Should I use something different?
Any help would be much appreciated!
Steve
9 REPLIES 9
Message 2 of 10
Re: Help configuring TP Link TD-W8961N
Username is normally
[email protected]
Message 3 of 10
Thanks, I tried it but no luck.
Don't know if these error logs help
CHAP: login to remote failed; please check user/pswd
netMakeChannDial: err=-3004 rn_p=80490368
Last errorlog repeat 9 Times
Message 4 of 10
The Line State is Showtime so it seems like it should work... But it doesn't...
Message 5 of 10
What sort of broadband do you have? The TP Link TD-W8961N is designed to work on an ADSL line so will not work if you have FTTC BB.
(If I have helped you in any way please click the thumbs up. Thank You)
If I have solved your Issue please click the "Mark as accepted solution" button.
Message 6 of 10
I have a ADSL.
The old modem/router that was plugged in died a few days ago. It was a third party O2 Thompson router that had been plugged in since 2014 or maybe even as far back as 2010. Was working fine til now. I would have logged into the router to copy over the credentials to the new TP Link but the old router's WiFi is no longer being picked up.
I tried not using any bt username or password in the new router setup and the CHAP login error is gone now. But I get this now:
ADSL: UP
MPOa Link Up
Quick bridge not allow multi-channel
bridge only stop
SNMP Trap 3: link up
Message 7 of 10
If I ask BT to send me a new router/modem, can I just plug it in with no setup required?
Message 8 of 10
I think if you renewed your contract with them you would get a router sent out, however plenty of 2nd user Home-hubs available on auction sites
Message 9 of 10
That would be correct. You would be best with a home hub 4, as that is more suitable for ADSL.
Message 10 of 10
Thanks for your help, guys. I'll get a new BT router and let you know..
