Message 1 of 3
Hybrid connect
I have been trying to turn off the main blue light on my hybrid connect box using the MyBT app on my phone. I can switch from High too Off and save the changes, but the light does not go off and when I check the app it shows that the setting is on high. Anybody have any idea what to do next?
2 REPLIES 2
Message 2 of 3
Re: Hybrid connect
I read that the only solution to this is low tech. Black insulting tape. Wait for the fix to follow
Message 3 of 3
Re: Hybrid connect
Hi thanks for that, black tape was going to be my next move if nothing better came up.
