Message 11 of 17
Re: IPC6023
Hi @NeilO @JohnC2 -I’ve completed all those tests as well, but no joy.
As with the previous poster, it seems to be a box problem as everything else connected to the internet in my house works just fine (including Now TV and BT Sport apps on my tv ironically).
Can you please confirm what next steps I can take please, as the box thinks it’s working and connected and has worked fine for months and now it isn’t.
Message 12 of 17
Re: IPC6023
Hi @Danrobbo65 I'm sorry that didn't work, one more thing to try is a factory reset ensuring to choose the option to keep your recordings.
  1. Switch the box off and then back on again. A red light should appear on the front panel
  2. Press and hold the down arrow button on top of your box for five seconds until you see ‘Enter Maintenance Mode Y/N’ at the bottom of the screen. When you see this, press the standby/power button
  3. After a few seconds you’ll see the ‘Maintenance Mode’ menu. Choose and select Factory reset, keep recordings using the arrow buttons. This option will allow you to keep your recordings, scheduled recordings, and any personal settings you've made to favourites and playlists
Let me know how you get on?
Neil
Message 13 of 17
Re: IPC6023
Hi @NeilO @that seems to be worked.
Thanks for the help.
Message 14 of 17
Re: IPC6023
Nice one @Danrobbo65
I'm glad that worked.  I'll let @NeilO know that you've posted back.  Enjoy the rest of your day.
All the best,
Robbie
Message 15 of 17
Re: IPC6023
I am having the same issue since having FTTP installed.
Having tried everything on the list and still not getting a resolution I’m out of ideas. The TV box has been factory reset, the ONT has been reset and yet still I always get IPC6023 issue. It’s not even as if I get the issue, reset the ONT and then it works for a period of time. I simply cannot get any picture on IP channels yet apps and other internet services work.
An engineer has also visited my property but still no solutions. Any other ideas out there to fix this?
Message 16 of 17
Re: IPC6023
Hi @Jtothed1, welcome to the forum, and sorry that you are getting this error code.
Are you getting this error still?
If you are still getting the error, have you followed the previous advice on the thread step by step?
Cheers
John
Message 17 of 17
Re: IPC6023
Trying to follow the steps to do a factory re-set. Pressing and holding the down arrow button on top of your box for five seconds has no effect and YouView starts. Within YouView settings, a factory reset states you will lose all recordings (not acceptable). Thoughts?
