Message 11 of 17
Re: IPV6 with Netgear....is this still an issue?
Sorry to resurrect this from the dead, but I figured it would help someone else out.
I just purchased a Netgear Nighthawk RAXE300. As far as I can tell, I cannot get it to work with IPv6 & IPv4. So adding my vote to the "don't by netgear for IPv6" pile.
Message 12 of 17
Are you say IPV4 is an issue too?
Message 13 of 17
It seems to be mutually exclusive. After trying all of the settings under IPv6 I could find, the best I ended up with was either:
- IPv6 works, but no IPv4
- IPv4 but no IPv6
Message 14 of 17
Are you thinking you can use both at the same time ?
Message 15 of 17
@gntr8102 What does https://test-ipv6.com/ show?
Bear in mind BT use only IPv4 for both IPv6 and IPv4 DNS lookups.
Message 16 of 17
@Stu_HI'm not sure what you're getting at here? I was at the very least expecting to be able to resolve not just IPv6 addresses, but IPv4 as well.
My understanding, upon further reading is that BT uses IPv6 with PD, and that Netgear has refused to support this.
In any case, the router is being returned.
Message 17 of 17
Don't have the router plugged in any more. I recall when testing with https://ipv6-test.com/ I had either:
- IPv4 Connectivity all unsupported (with IPv6 connectivity), DNS4 + IP6 working, DNS6 + IP6 working
- IPv6 Connectivity all unsupported (with IPv4 connectivity), DNS6 + IP4 working
I tried with using BTs DNS servers, Google, NextDNS and all had the same results from what I can remember.
In comparison with an ASUS router I have switched to (AX86U), I have the following (after testing now):Screenshot 2023-02-05 at 13.57.39.jpg
