Message 1 of 12
I've recently upgraded to FTTP and have digital voice.  I'm looking at getting an IPV6e router, will digital voice still work through a non-BT router?
11 REPLIES 11
Message 2 of 12
Re: IPV6
@tmarsh12345
No it will not, authentication and the DECT base station are part of the smart hub 2.
Message 3 of 12
Re: IPV6
The SH2 supports IPv6
Message 4 of 12
Re: IPV6
Yes but likely not 6e?
Message 5 of 12
Re: IPV6
IPv6e being?
Never heard of it.
Message 6 of 12
Re: IPV6
What Is Wi-Fi 6E?
Wi-Fi 6 and previous generations of Wi-Fi use the 2.4 GHz and 5 GHz radio bands. A “Wi-Fi 6E” device is one that is capable of operating on the 6 GHz band, too.
The 6 GHz spectrum should work similarly to WiFi 6 over 5 GHz but offers additional non-overlapping channels. As the Wi-Fi Alliance puts it, Wi-Fi 6E allows for “14 additional 80 MHz channels and 7 additional 160 MHz channels.” These channels wouldn’t overlap with each other, which will help reduce congestion, particularly in areas where lots of networks are operating.
Message 7 of 12
Re: IPV6
So absolutely nothing to do with IPv6 at all!!!!
Message 8 of 12
Re: IPV6
I'm asking if I can have digital voice if I buy an IPV 6e router.
Message 9 of 12
Re: IPV6
No you're not, you're talking about Wifi6, not IPv6 which is something entirely different.
Message 10 of 12
Re: IPV6
Sorry, I meant wifi 6e.
