Message 1 of 9
LOS light is on red
Hi,
My Broadband and landline has not worked since 05:00 this morning (2nd September 2020) and  LOS light is on solid red despite taking the power on and off several times.
I can’t get through to the call centre all day!!
Please Help!!
8 REPLIES 8
Message 2 of 9
Re: LOS light is on red
have you checked 'service in my area' to see if it is a fault with your line or general fault affecting others  go to 'help' at top of page
Message 3 of 9
This is what it said under broadband open fault:
“Problem fixed
Reported Tue 18/08/2020 at 05:23 PM
Issue Ended Wed 02/09/2020 at 05:10 AM
We've fixed the recent problem in your area. To get your broadband running smoothly again, restart your BT Home Hub. Just turn it off at the mains, wait a few seconds, then turn it back on again. Give it a couple of minutes to finish starting up.“
I’ve had turned it off and on several times and still not working.
Anonymous
Not applicable
Message 4 of 9
Big problems in Coventry (assuming that's where you are)
Message 5 of 9
No, I live near Cambridge
Message 6 of 9
Did you also turn the power off on the modem, waited about 20 seconds, and then turned it on again?
Message 7 of 9
Yes I did. Waited 30 seconds… turned off for 1 minute and then on… LOS light is still on red…
Message 8 of 9
It might be best to call the FTTP helpdesk on 0800 587 4787.
Its possible that there is a disconnection in the optical network. Its odd that it started at the time when service was supposed to be restored. Perhaps a fibre was taken in error, to fix a fault?
Message 9 of 9
Care to narrow it down a bit?
