Message 1 of 11
Large Evening Speed Slowdown
Hi everyone,
I just wanted to pick your brains as I've had good help from here before  🙂
Since about 2 days ago I'm seeing a large slowdown from mid afternoon to all evening in my speeds.
Had solid 66-68 Mbps speeds for years, and now get 30-40 Mbps in the morning and 6-8 Mbps at night.
I've reported it and had a new Hub sent, which arrived today, but has made no difference.
I have an engineer coming on 28th December, but the timed nature of the slowdowns make me think it's exchange congestion, is there any way of finding this out for sure ?
Thanks for any help.
Tags (3)
10 REPLIES 10
Message 2 of 11
Re: Large Evening Speed Slowdown
If your connection (sync) speed remains constant but your download speed drops, there is a distinct possibility it is due to congestion.
Message 3 of 11
Are you using Ethernet or wireless?
can you run btspeedtester with Ethernet connection and post results   Can you run when download ok and again when poor
https://speedtest.btwholesale.com/
which exchange and cab are you on?
Message 4 of 11
your sounds like the same has mine you don't live in Milton Keynes do you
Message 5 of 11
Hi,
Thanks for the replies:
Ethernet connection.
BTWholesale Speedtest taken just now:
Download: 6.96 Mbps
Upload: 17.06 Mbps
Ping: 35
Holland on Sea exchange
Cabinet 3
Message 6 of 11
No, Holland on Sea here.
Message 7 of 11
@Ian
I have asked mods to check your exchange for problems
Message 8 of 11
@imjolly
Thanks, thats much appreciated !
Message 9 of 11
Hi @Ian
I've dropped you a private message asking for some more information, so we can investigate these speeds in the evening for you.
Stuart
Message 10 of 11
Thanks @StuartH , thats very kind of you, I have replied to your message as requested.
