Message 1 of 8
Limited download speed - DLM?
When I had BT broadband installed my download speeds were above my minimum guarantee (100mbps). Then I had a period of the connection dropping out (which I think was due to my powerline adapters as I've switched to an ethernet cable and the problem has stopped), and after that my speed seems to be stuck at around 29mpbs.
Reading around a bit my guess is that my download speeds being reduced to to line instability and DLM. How can I check if this is the case, and now I've sorted the instability issue, how can I get the speed back up again?
7 REPLIES 7
Message 2 of 8
Re: Limited download speed - DLM?
As long as your connection remains stable DLM will eventually relent and increase your speeds again.
Meanwhile can you post the connection stats from the hub. Advanced settings/technical log/information.
Message 3 of 8
Here's the technical log data
Product code:Smart Hub 2
Serial number:+091299+2044012981
Firmware version:v0.26.04.04227-BT
Firmware updated:Thu May 20 23:13:13 2021
Board version:R01
GUI version:1.74 12_11_2020
DSL uptime:0 days,07 Hours45 Mins50 Secs
Data rate:13.077 Mbps / 29.116 Mbps
Maximum data rate:12.687 Mbps / 26.879 Mbps
Full Fibre (FTTP) Mode:Off
Noise margin:8.6 / 26.3
Line attenuation:0.0 / 39.5
Signal attenuation:0.0 / 39.5
VLAN id:101
Upstream error control:Off
Downstream error control:Off
Data sent / received:604.7 MB Uploaded / 3.6 GB Downloaded
Broadband username:[email protected]
BT Wi-fi:Activated
2.4 GHz wireless network name:BT-X5A3WJ
2.4 GHz wireless channel:Smart (Channel1)
5 GHz wireless network name:BT-X5A3WJ
5 GHz wireless channel:Smart (Channel36)
Wireless security:WPA2 (Recommended)
Wireless mode:Mode 1
Firewall:On
MAC address:E4:75:DC:EB:8B:CC
Software variant:-
Boot loader:0.1.7-BT (Thu Nov 30 09:45:22 2017)
Message 4 of 8
these stats don't suggest anything like a 100mb connection  can you enter your phone number and post results please
remember delete number
Message 5 of 8
Here's the results
Message 6 of 8
From your initial post I assume you are on G.FAST.  you speeds are no where near expected and explains the very high noise margin.  Do you have a dial tone on your landline?
Message 7 of 8
Yes I am on G.fast
I've just checked the phone and I have a dial tone
Message 8 of 8
If you have a dial tone and there is no line noise then report a fault
