Message 1 of 12
Losing wifi connection
During the last few weeks I have been continually losing my wi-fi connection.  The connection drops out randomly for around an hour at a time. The line was checked and is fine, the router is fine, (I have tried 2 routers- one being brand new), the only other part is the BT Openreach modem - is this likely to be the fault.  I have tried re-setting this but doesn't seem to do anything.  Eventually the wi-fi just starts again - any ideas what it may be - I really need wi-fi for work
11 REPLIES 11
Message 2 of 12
Re: Losing wifi connection
Are you losing WiFi or are you losing broadband? If you are losing WiFi it won't be a faulty modem. Does the DSL light on the modem change when you lose connectivity?
Message 3 of 12
Yes  losing WiFi  the modem lights are all on, when wi-fi is off
Message 4 of 12
Have you tried changing channels, do you get any drop outs with a wired Ethernet connection.
Do you lose connection on all devices or just one?
Message 5 of 12
I do have all my office PC's on ethernet, and lose connection on those as well.  The signal is lost - the red light is on- on the router - and I cant get a signal on anything.  Usually after around 1-2 hours it comes back on again, fo apparently no reason
Message 6 of 12
So you are not losing WiFi, you are losing broadband. Which home hub do you have, if it is a HH 5 or later you don't need the modem unless you have FTTP and you are referring to an ONT.
Message 7 of 12
are you a business user?
Message 8 of 12
I work from home on a permanent basis.  the BT openreach modem is a 3B, my router is a Netgear nighthawk X6 - sorry dont know what  'FTTP and you are referring to an ONT'  means
Message 9 of 12
just to clarify - so you are a residential user but using your line to run a business?
Message 10 of 12
Yes I work from home
