Message 211 of 366
Re: MacOs 11 compatibility with Virus Protect no j
@occoldman What version of BT VP are you using. I have version 4.10.1.0 and haven’t experienced any issues.
Message 212 of 366
I have it running on 1 Mac okay, but it absolutely refuses to run on another. It's not an old machine either.
Message 213 of 366
Hello Steve,
Yes, I'm also using 4.10.1.0 so it's strange that it should perform differently.
Message 214 of 366
Message 215 of 366
Exactly the same for me
Message 216 of 366
Yes it does for a while and then stops, at least it stops for me
Message 217 of 366
I have installed the new version from MyBt but every time I run a scan using BT Virus Protect my MAC crashes and a report is sent to Apple.  Is that common as well?
Message 218 of 366
Good afternoon watkinmc and a happy New Year to you.
Hopefully, by this time next year we will have fully functioning antivirus software.
With regard to your specific question, I can run a full scan without it crashing. I have run full scans several times over the past four weeks and there has been to problems.
Regards  occoldman
Message 219 of 366
This has now been going for so long and still has not been sorted out. How much longer is this going to take and how much compensation are you going to give everyone for not being able to use Mcafee properly as we are paying for only part of the product ?
Message 220 of 366
@SeanD  any update on planned release of the firewall fix?
