Message 21 of 23
Re: Master Socket - Move options and Cost
disconnected all other extensions and speed even worse.
does anyone have the info on moving a master socket and cost.  i'd like to at least evaluate it.  thanks all for you help, back to the garage i go
Message 22 of 23
Try local paper for telecom engineer (not electrician) as will be cheaper than openreach and probably ex openreach anyway
Message 23 of 23
connected back up as was, and after all that, I've got a slightly better upload speed 😂.  every cloud......
