Message 61 of 83
Re: Mitel Office IP Phone DHCP Discovery Issue
I’ll buy it and give it a go! I really hope it works🤞🏼
Thank you for all your help, will update you when I’ve plugged it all in!
Message 62 of 83
Its difficult to suggest anything else. Its just a bit odd that the BT hub is not responding to a DHCP request from the phone. Without setting up a separate DHCP server its difficult to prove.
On thing that may work, has it been suggested that you configure the IP phone, so it does not use DHCP, and instead, configure it for a static LAN IP address?
Can you actually access the configuration settings on the IP phone?
If you can, it would be very simple to setup a static LAN IP address.
Message 63 of 83
I do have my old BT Residential hub if that would work?
Message 64 of 83
I do still have my old BT Residential router which is Full Fibre 500 would that work?
Message 65 of 83
No, you cannot change the login details for that.
Did you see my question regarding the IP phone settings, as that would be an easy thing to try, as it should overcome the DHCP issue?
Message 66 of 83
@meg_
What model is the Mitel Phone?
Kind Regards
CJT80
Say thanks by clicking the Thumbs Up icon. Have I resolved your issue? Click "Mark As Accepted Solution"
Message 67 of 83
I can configure it, how would I set up a static LAN IP address?
Message 68 of 83
If it has a setting page, then change the network settings from DHCP to static IP (manual settings), and enter the following.
IP address 192.168.1.50
Subnet mask 255.255.255.0
Default gateway 192.168.1.254
DNS server 192.168.1.254
I an fairly sure that the business hub uses the same IP subnet details as the home hub.
If you access the business hub from 192.168.1.254, then that would be correct.
I would have expected your employer`s IT department to have suggested this first.
Message 69 of 83
Mitel 5312 IP Phone
Message 70 of 83
https://ctsolutions-inc.com/mitel-5312-5324-ip-phone-user-guide-5.pdf
Its complicated, I cannot actually see where the network settings are, but @CJT80  may be able to find them.
