Message 11 of 18
Re: Moving houses and found out it doesn't have fibre
Whilst not absolutely impossible, it is extremely improbable that the houses either side of you are fed from a different cabinet.It is far more likely to be a records error.
Message 12 of 18
Thanks @licquorice
I've gone and contacted Openreach to see what is going on.
They came back an hour or so ago saying that they will investigate and will need the help of their lineloss team.
Message 13 of 18
Which exchange are you on, you have deleted it from the screenshot? I assumed Mildenhall from the message in yellow, but it would appear that that message appears regardless of location.
Message 14 of 18
Its Huntingdon @licquorice
Message 15 of 18
Hello neighbour, I'm about 10 miles away. 😁
That's totally weird, cabinet 17 is nowhere near cabinet 80
Are you in Brampton or Hinchingbrooke?
Message 16 of 18
😯neighbour! didn't expect to find people around me here!
We will be in Hinchingbrooke close to the park.
Hopefully Openreach will have a good news for me next week.
Message 17 of 18
In that case, I very much suspect it is a database error and you will be connected to cab80 with good speeds.
Message 18 of 18
Yup! It was that.
Openreach said they will contact me back latest yesterday but no luck there. However, after checking their site, it is now showing much better connectivity.
