Message 11 of 15
Re: New house - socket has cat5 plug
Yes it does plug in. It's just doesn't work.
Message 12 of 15
If you have a spare microfilter, try connecting it up as shown below, and see if it works, and you can still get dial tone on the phone. You will have to unscrew the front plate to get to the test socket. Your one will be slightly different as it an ADSL faceplate, but its the same behind.
Message 13 of 15
Update: None of the above worked. BT chap came and replaced the box.
Message 14 of 15
OK but is your broadband now up and running?
Message 15 of 15
Yep, 7Mb down and 1Mb up, but that's another story...
