Message 11 of 19
Re: No internet on activation day.
I did a speed test right after I got the confirmation text earlier today. About 35 down, 8 up, which is consistent with past results. I was watching a Twitch stream at the time it went down. Never had issues before (with Plusnet or BT before that).
Edit - No issues listed on the service status page.
Message 12 of 19
As I said, check the online status page, as it could be a network fault, as there are a few showing, depending on what part of the country you are.
Message 13 of 19
It does seem odd. All you can do is to report it to BT as a fault. It will be classed as an Early Life Failure, and should be dealt with fairly quickly.
Message 14 of 19
I just got off live chat and they told me my account isn't set up yet, and to call a number where they can get my broadband working now. The lines are closed for the night, but I can't call anyway due to disability. I've had moderators here help me with similar situations that required phonecalls before, if there are any reading this, please help.
Message 15 of 19
The moderators are very busy, and it would take a few days before they could even look at your case.
Its quite possible that it will sort itself out within 24 hours anyway, as there may be a pending configuration change, as you may have been connected to a port which was active from another customer.
Message 16 of 19
Thanks for your time and effort in trying to help. I appreciate it.
Message 17 of 19
Hi @Jedimaster I'm really sorry your broadband isn't working, I'll send you a private message in a moment so you can get in touch with the moderation team.
Message 18 of 19
Just to update this thread, the account side of this issue has now been fixed, and I have an engineer visit booked for Wednesday. Thank you to everyone that helped. I appreciate it.
Message 19 of 19
Engineer came today, and was great. He said I had broadband, it just wasn't mine so the hub couldn't authenticate. He left and corrected the mistake that was made at the cabinet on my activation day.
I consider this resolved.  Thanks to everyone that helped.
