Message 31 of 46
Re: Noise margin change and speed loss
My line did use to target 3dB and it ran at 67mbps.
Message 32 of 46
Capture456.JPGHi all, heres an update. My router has not disconnected however I have noticed the margin has dropped to 5.6 and the max speed is now less than the speed I am connected at. Is this bad?
Message 33 of 46
Nothing to worry about, it'll sort itself out over the next few days.
Message 34 of 46
Hi all,
My broadband has been stable for 7 days now and im really happy with it. However I have just noticed our land line is dead, Theres no dial tone and we can't call the house. As we hardly use the landline I'm not sure if its been like this for 7 days since the engineer came or if theres a problem in my area at the moment. Any ideas?
Message 35 of 46
If you go to help at top of page you can check service in your area.
Have you moved to Digital voice?
Message 36 of 46
I checked the service in my area and theres no known issues, we havn't changed our package at all or requested to go on to digital voice.
Message 37 of 46
Would a line test show if my landline was disconnected at the cabinet?
Message 38 of 46
How’s it going now? @shermsta
Message 39 of 46
Hi we had another engineer come out who found that we had a short circuit on our line. He went to the cabinet and sorted it out. The phone now works and the broadband has been very stable at 62mbps 🙂
Message 40 of 46
That’s brilliant you have any line stats you can share?
Thank goodness it’s sorted 🙂
