Message 1 of 8
Nowtv app
I have bt big sport with hd bolt on. Sky and bt sports. The now tv app says i need a pass to view content. I have a pass but no access. Any ideas?
7 REPLIES 7
Message 2 of 8
Re: Nowtv app
Hi @Chrisso1 welcome to the forum and sorry you can't access the Now TV App. Have you completed the activation of the App with the link that was in your order acknowledgement?
cheers
John
Message 3 of 8
Re: Nowtv app
Iwas already using nowtv then moved to bt. I didn't see any activation email.
Message 4 of 8
Re: Nowtv app
Hi @Chrisso1, it could be that a different email address has been used. Check out Getting Started with Now TV as existing Now TV customers should use the existing email address.
The activation information would have been included in your order confirmation which would have been sent a few minutes after you placed your order. You may need to check your Spam/Junk folder. Let me know how you get on.
cheers
John
Message 5 of 8
Re: Nowtv app
I found the bt email. Changed my password. Still says i need a pass. I have my chromecast registered on there. So i must have a nowtv account.
Message 6 of 8
Re: Nowtv app
Hi @Chrisso1, I'm sorry about that, when you were setting up the Now TV password did you use the email address that we emailed the order confirmation to as your username?
Neil
Message 7 of 8
Re: Nowtv app
Yes i used the same email that i use with all correspondence.
Message 8 of 8
Re: Nowtv app
@Chrisso1 thanks for confirming that, we'll be happy to take a look at your subscription to make sure it's set up properly on our side. I'll send you a private message so you can get in touch with the moderators.
