Message 1 of 21
Openreach wont drop SNR
Hi All
I am having a mare and wondering if someone can help my downstream snr is stuck at 8db i want it lowered had 2 engineer visits neither wanted to do it because im getting 67meg
Ive lived in the flat upstairs 3db for 2 years no issues.
Please help
Product name:
BT Hub 6A
Serial number:
+084316+NQ74439782
Firmware version:
SG4B1000E020
Firmware updated:
12-Jan-2021
Board version:
1.0
Gui version:
1.115.0
DSL uptime:
0 Days, 6 Hours 16 Minutes 59 Seconds
Data rate:
20.00 Mbps / 80.00 Mbps
Maximum data rate:
26025 / 90949
Noise margin:
9.6 dB / 8 dB
Line attenuation:
20.9 dB
Signal attenuation:
13.6 dB / 20.9 dB
VPI / VCI:
0/38
Modulation:
G_993_2_ANNEX_B
Latency type:
Fast Path
Data sent / received:
695 MB Uploaded / 2 GB Downloaded
Broadband username:
BT Wi-fi:
Active
2.4 GHz wireless network name:
BTHub6-7R9C
2.4 GHz wireless channel:
Smart (Channel 6)
5 GHz wireless network name:
BTHub6-7R9C
5 GHz wireless channel:
Smart (Channel 36)
Wireless security:
WPA2 (Recommended)
Wireless mode:
Mode 1
Firewall:
On
MAC address:
A0:39:EE:67:3F:95
Software variant:
Boot loader:
9.2.0
20 REPLIES 20
Message 2 of 21
Re: Openreach wont drop SNR
Your SNR is high because you are receiving the maximum speed possible 80M.
Message 3 of 21
Yeah but i had the same in the upstairs flat and managed to get it lowered.
Message 4 of 21
You are at the maximum speed for fibre 2. SNR figure is totally irrelevant.
Message 5 of 21
Im not because my throughput is 71 meg. I did say!
Message 6 of 21
Your sync speed is 80M, the maximum for fibre2, and governs the SNR figure. Throughput will always be lower than sync speed and has nothing to do with SNR.
Message 7 of 21
Then how come when I got it lowered to 3db I hit 75 meg? I know what I’m after I’m sick of going around in circles!
Message 8 of 21
I can assure you SNR is only related to sync speed and not throughput and as you are syncing at maximum speed it is totally irrelevant. It is impossible to lower it.
Message 9 of 21
As @licquorice has said your noise margin is high at 8db and is correct as you have max connection speed of 80mb but a far higher attainable speed. You will not get a lower noise margin unless your difference in speed between actual and attainable reduces.
Message 10 of 21
Sorry but that’s bs because  74 meg on 4db what I got in the flat upstairs last summer... same bloody junction box.
this is what frustrates me... lower the SNR. Job done.. what’s so hard about it!!
