Message 21 of 26
Re: How to turn off hot spot?
Sound like something a lawyer would need to argue
the phrase (BT Broadband customers only) could be interpreted as if you have broadband only or if you have broadband regardless of mobile.
I read it as if you have broadband, then if you opt out you loose the right to use it for any service you have but I see that its certainly not written clearly (well at least for my non legal reading) and you are probably right ?
Message 22 of 26
It does not need a lawyer.
Access to BTWifi is part of the BTMobile package. It is NOT dependant on the user being a BT Broadband customer. They are two different packages with their own T&Cs.
Message 23 of 26
Has the OP lost access ?
Message 24 of 26
I have no idea but if he does it will be restored because it is a clear breach of his BT Mobile package and what he is paying for.
Message 25 of 26
From your reading, I certainly agree he should have. Fingers crossed.
Message 26 of 26
Going slightly off topic here guys so I'll lock this thread. Thanks all for posting.
Cheers
David
