Message 2 of 6
Re: Internet Problem reported to BT over a month ago still not fixed
Trying to contact BT is a joke! A communication company? Get some bloody communications going then!
5 REPLIES 5
Message 1 of 6
Re: Poor Fibre connection
My internet has been like a yo-yo for weeks now. Been in contact with BT but to no avail.
offered a new 24 month contract to me last Saturday, which I stupidly took out .
Think I’ll call them tomorrow and cancel (within my 14 days) and go to $ky. cheaper and according to others that I know, much more reliable
Over £60 a month - P!ss poor!
Message 3 of 6
@boybeckham i suggest you start your own thread detailing your problem, also include the home hub stats so one of the experts he can help you out
(If I have helped you in any way please click the thumbs up. Thank You)
If I have solved your Issue please click the "Mark as accepted solution" button.
Message 4 of 6
Hi @boybeckham,
Thank you for posting I'm sorry you've be been experiencing issues with your connection. I've moved your post onto your own thread where it will be easier to get help.
To get a better understanding of how the connection is performing and what can be done to improve things, please could you post the router stats as suggested by @Devon_Dave?
PaddyB
Message 5 of 6
@boybeckham I am sure that unless you go to Virgin, Sky and BT both use the same openreach external cabling network.
That is where you problem could be.
Message 6 of 6
in order for the forum members to try and help please can you post the stats from your router (if hub enter 192.168.1.254 in your browser) and if  HH5 then go to troubleshooting then helpdesk and if HH6/SH2 then advanced settings then technical log information .
Have you tried the quiet line test? - dial 17070 option 2 - should hear nothing - best done with a corded phone. if cordless phone you may hear a 'dull hum' which is normal
have you tried connecting hub to the test socket with a filter to see if that stabilises your connection
do you use powerline adapters which from other posts can cause problems
enter your phone number and post results  remember to delete number   https://www.broadbandchecker.btwholesale.com/#/ADSL
Someone may then be able to offer help/assistance/suggestions to your problem
