Message 11 of 19
Re: Replacing BT Home Hub with Google Nest WiFi Issues (FTTP)
No idea, but it won't hurt to do so.
Message 12 of 19
will i loose all my connections if i do the rest ?
Message 13 of 19
I've tried all of these but still no broadband, I've just got BT broadband today do I have to connect their router to the network first to activate anything ?
Message 14 of 19
You might need to use vlan id 101
Message 15 of 19
Where do I put the vlan etc
Message 16 of 19
Apologies with PPPoE on OR FTTP vlan id is not needed.
It just needs the username and anything for a password or blank.
Message 17 of 19
I have fttp 500mb activated today all the lights are on the ont etc but on set up still says no Internet?
Message 18 of 19
thanks for all the help guys, i actually got the BT router delivered this morning after getting no where last night, i plugged it in and NO BROANDBAND hub on orange so now have to wait for an engineer on tuesday, thankfully Virgin doesnt get diconnected until friday.  So now going around the house connecting everything again!
Message 19 of 19
thanks, the login and "bt" as the password worked, it was the back end where the issues were.....
