Message 1 of 14
'Request Entity Too Large' error when signing in
Just got this error again while trying to use the forum.    See screen grab below using Chrome
There is a solution:  clear all cookies associated with BT but I suggest many users won't be aware of that and those that do might not be aware how to selectively clear cookies by site
So some sort of design fault is there with how BT are using cookies and that's the problem that needs to be fixed please
13 REPLIES 13
Message 2 of 14
Re: 'Request Entity Too Large' error when signing in
I have seen this issue as well, with Google Chrome. Clearing cookies fixes it.
There are 77 cookies, just for this forum, another 49 from bt.com.
Message 3 of 14
Hi guys,
Thanks for highlighting.
Sorry you're seeing this issue.  I'll be sure to get this reported.
Cheers,
Robbie
Message 4 of 14
I used to have this problem quite a bit. Now I just clear the cookies on exit.
Why do they want to set so many -- they are no use to me!
Richard
Message 5 of 14
There seems to be a cookie set for every thread you visit. That shows when you look at the actual cookie content and the url it contains.
Lots of btVisorga cookies.
Message 6 of 14
@RobbieMacwrote:
Hi guys,
Cheers,
Robbie
Well if you reported it they did nothing as the fault is still there
Message 7 of 14
I had the error last week.
(If I have helped you in any way please click the thumbs up. Thank You)
If I have solved your Issue please click the "Mark as accepted solution" button.
Message 8 of 14
Problem is still present today
Message 9 of 14
Clearing the community.bt.com cookies is the only cure.
Message 10 of 14
Not for Khoros to fix this poor programming?
