Message 1 of 2
Router Upgrade
Hello,
I currently have a BT Smart Hub but have been thinking of replacing it.  I have  been getting random dropouts and connectivity is inconsistent through the house.
I had been looking at the nighthawk range but unsure which is suitable.
I have my BT smart Hub located in a hallway near the front door so cant have too many hubs/routers/devices taking up space.(Ideally just the one device connected to the wall)
Is it as simple as purchasing a modem/router that can replace the BT Smart hub?
Thanks,
1 REPLY 1
Message 2 of 2
Re: Router Upgrade
Yes, as long as you get the right type. If you have fibre1 or fibre2 any VDSL modem/ router will suffice. If you have G.Fast your options are pretty limited.
