Message 11 of 15
Re: Silver Address Issue
As its an FTTP connection, having a phone number is optional, as it would be delivered using BT Digital Voice. I am sure things will work out fine. Perhaps you could keep this thread updated, just in case you need more help.
Message 12 of 15
Morning Ketih,
I ordereed a phone line, which was then cancelled as BT had advised that is there is FTTP then we would need a Digital Voice instead.
Since then we had someone from OpenReach come and view the property on 4th Nov.
I can see our address has now been showing on BT's website for 2-3days, but when we try to make an order we only get a message to say it isnt available yet?
It's been a few weeks of us trying to get this resolved. do you have any further advise on how to take this further? we really need broadband in the property asap
Message 13 of 15
@SimonBeckley
Its possible that FTTP is not yet available, but perhaps you can use 4G broadband meanwhile, if its available.
If Openreach have been to look at it, they you will have to wait for the result, as they would pass the information back to BT Retail.
Message 14 of 15
Thank Keith, we do definitely have FTTP. i think its just an error on Openreach where they have the address down as something different.
Do you have any idea on the lead times for this?
Message 15 of 15
Hi @SimonBeckley
Thanks for your posts and welcome to the BT Community.
I am sorry for the problems you've been having getting service connected at your address.  I appreciate the time you have spent up to this point trying to get this resolved.  As you seem to be going round in circles we'll pick this up from here and we will find out what needs to be done to get you up and running.
I have sent you a private message with instructions on how you can send us over your details and we'll look into this for you. See: Private messages
Cheers,
Robbie
