Message 1 of 14
SkyGo app
Hi. My sky go app will not play channels when I am
on my home wifi. It says that I am watching in a different country.
The app works fine in a different house on a different wifi. Any ideas??
13 REPLIES 13
Message 2 of 14
Re: SkyGo app
Is anyone running a proxy server or VPN?
Message 3 of 14
Re: SkyGo app
I don’t think so. I’ve just had bt installed and connected the device to it to watch skygo.
Message 4 of 14
Re: SkyGo app
Try restarting the hub, it should pull through a new IP address
Message 5 of 14
Re: SkyGo app
I tried that twice today but still doesn’t work
Message 6 of 14
Re: SkyGo app
And you're sure you're not using a VPN? What device is this from?
Message 7 of 14
Re: SkyGo app
Hi, it’s on an Amazon kindle
Message 8 of 14
Re: SkyGo app
It looks as though the Sky Go app isn't officially available on Amazon Kindle. Have you side loaded it?
Message 9 of 14
Re: SkyGo app
I just downloaded it from the kindle App Store. It works fine at my friends house, who also has bt internet. Just doesn’t work at my house
Message 10 of 14
Re: SkyGo app
I've just been reading through the Sky forums and lots of people are having the same problem across different ISP's and the common denominator seems to be a VPN that's embedded in antivirus software. In most cases this is Norton antivirus. It also doesn't seem restricted to Kindle
